Dodge Dana 60/70 help
front 60 = 200-300 max range . otherwise its no good for our trucks for bolt in . there 4 link/coil spring style. unit bearings . no locking hubs . ball joints . and central axle disconnect if optioned and like to break under heavy use.
1g for the pair is crazy. Plus it being a coil front suspension truck that makes it a lot more work to install in your rig. And, someone correct me if I'm wrong, but that front D60 is a ball joint unit too.
SweetK30 pointed out that it was a ball joint axle. I didn't even notice that it was a coil front until I posted this thread. It's way more work then I'm interested in so I'll pass
