dodge dana 60 steering arms
I have one off a 1984
Only problem is, it is attached to the complete dually axle
I know; I'm a lot of help
You might check ORU for a raised steering arm for D60's. They offer them for the stock push-pull steering and crossover, too.
Are you wanting a Dodge arm for the height of it over the GM arm? I did the same thing and had Kert weld up the taper hole and retaper it from the opposite side so the drag link would fit in thru the top side rather than bottom.
Yup exactly! Have friend building a couple trucks.
