73redblaze
Im losing my mind with the death wobble on my dodge. Its the worst wobble I have ever experienced. it only happens when I hit a bump but the wheels shake right to left so bad that I can barley keep it in my lane. its a 2004 dodge 2500 straight axle with coils. 5" lift with 35s. now iv replaced the ball joints, bought a dual stabilizer kit, replaced draglink and tie rod (ends are welded on one side, had to buy new) replaced the track arm bushings. I had it aligned and had the wheel bearings checked. I even put in the kit that says it will stop dodge death wobble. it wraps around your steering box and ties the frame together, no luck. The ONLY thing I can think of is the tires are at about 30%. my tire guy says it would shake all the time if that were the case, not when I hit a bump. Does anyone have any ideas before I drop another grand in tires? please help!!
