Sans a broken belt I dont see how any radial tire in any given shape that it can rotate could cause death wobble...
So you're saying you've never seen an out-of-round radial tire before
Jack up one tire at a time just high enough off the ground that you can get a BIG pry bar under it and pry up. This whole grab the tire and shake nonsense works only if there is an obscene amount of play in something. The pry bar method will show you if you're starting to get play.
This is how I check ball joints, only I put a piece of plywood between the pry bar and tire so I don't damage it. I can also watch the ball joints while operating the pry bar with my foot.
So you're saying you've never seen an out-of-round radial tire before![]()
Make sure the caster of the front axle is correct. You said you just had it re-aligned, but when the caster is screwed up it can cause wobble in the wheel like that. Dodges are bad about having caster issues with a lift kit, thats why long arm kits are the way to go, and partly why the 4th gen trucks come with a factory long arm style suspension now.
