blazindorito
I was just quoted $365 for 100 feet.
The difference in 1 3/4 to 2" dia tube denting is so small you wont be able to even tell.
Has anyone ever actually done a dent comparason.....NO.
I bought 2" because I wanted to build my rig to some kind of spec. SCORE rules say over 4000 Lbs requires 2" tube. Even though My truck IS NOT a desert truck is does not mean I wont have a high speed crash on the freeway. So thats why I went with 2" tube. Its heavier but not by much in the end. the bigger tube looks tough too.
It bugs me when people say this about 2" just because they herd it from someone else without actually knowing the facts. Sure, common sence tells you bigger tube would dent easier, But how much is the difference in force required to dent 1 3/4 compared to 2"?.
If you go by that theory the why not use 1 1/2 tube or 1 1/4 tube.
I think SCORE has done their homework, their safety record in desert racing speaks for itself, hence the reason Im using some means of rules to build my cage by.
Ofcourse cage design is EVERYTHING when building a cage. If you build a cage out of DOM and its designed crapy, it could fair far easier then a cage designed and built from HREW tube which is weaker tube.
Assuming that the difference in denting is only based on leverage the then 2" would be 12.5%.
Just out of curiosity Im going to pinch a piece of 1 3/4 HREW and a piece of 2" HREW and measure the difference in deformation and calculate the difference.
Its been done thousands if not millions of times. If you want to compare yourself you can always put different pieces of tubing into a press and see how much load it takes to crush them (you can use some small point load to mimic the tube hitting a sharp rock).
Im sure it actually has been done, That WAS an incorrect statement on my part. I just feel you build a cage for overall structural safety not to be dent resistant. 2" may dent easier but is stronger because its bigger diameter, hence has more structural integrity.
Safety in a crash is a good reason to use bigger tube.
Agreed
I never said I heard this from anyone, I'm giving you the facts.
Where did you get the facts?
Most buggies use smaller diameter tubing. My chassis made up of 1 5/8" .120" wall DOM and 1.5" .090" HREW. I plan on flopping it and having the tubing remain usable. 1 5/8" tubing is 33% harder to dent than 2".
A buggie is fine with 1 5/8, their light. 33% harder to dent but how much easier to bend and possibly fail before 2" will?
Of course SCORE has done their homework. They plan on the vehicle being crashed at high speeds (more than 100 mph), not everyone building a cage plans for or needs that.
I agree 100%
quick hijack.
If i build a tube winch bumper, on my truck (which is a daily driver) what size tube would i want. and what wall thickness.
thanks
I don't know what most people use but I would probably use 1.75" .120" wall HREW.
HREW? It sounds framilier but i cant remember what it means. Would DOM tubin work or?
