A gas engine will usually speed up when it gets its fuel supply restricted or it runs out of gas,just before it stalls..a "lean surge",you have probably heard drag cars do it...does a diesel do the same thing too?..
Reason I ask,is my truck sometimes acts weird,like it suddenly got a dose of water in the fuel,or the fuel flow gets restricted,its done it mostly when the fuel tank has less than 1/4 of a tank...a few times in the past it stalled out while cruising along shortly after I put it under a heavier load,like to pull out into traffic or pass someone...it restarted OK though,without a long cranking period..
It had not done this in a long time,till yesterday...coming home from a doctor appointment,I was forced to take a detour due to road construction,and the street I had to use has a rather long and fairly steep uphill grade to it...the truck pulled the hill fine,but as I got just over the crest,I felt a loss of power,like it wanted to stall from lack of fuel--then it suddenly "surged" like it got a dose of nitrous or something,it only lasted a few seconds--then it drove normally the rest of the way home,on a fairly level road..
My theory is the tank was low enough on fuel to allow the fuel to run towards the rear of the tank climbing up the hill,and the sock filter didn't stay submerged,and air got sucked in the fuel lines...??...but I dont understand why the engine sudenly feels like a 454 for a few seconds right after it loses power...(wish it felt so gutsy ALL the time!
I stopped at the nearest gas station and put 5 gallons of diesel in it,I live only a 1/4 mile away,so I couldn't really tell if it would have done it again,I tend to think not...
Think I should break down and replace the fuel filter,which has been on the truck since I got it 10+ years ago,but has only been driven maybe 6000 miles since?...and fill the new filter up with some Power-Kleen or similar treatment to help clean out the injectors...I have tried draining both the fuel filter and fuel tank not that long ago and saw no trace of water in what came out,using the factory siphon valve on the tank plumbing and the filters bleeder screw & water drain...hate to toss 20 bucks away if the filter isn't clogged up or waterlogged...
)...I stopped at the nearest gas station and put 5 gallons of diesel in it,I live only a 1/4 mile away,so I couldn't really tell if it would have done it again,I tend to think not...
garuuummmm garuuuuummmmmm
