Does this look like work or play? (more pictures)
mountainexplorer
Spokane, Wa./Ione, Wa
It's supposed to look like work... but I have a way of putting a twist on things.
A quick meeting in the livingroom to discuss the obstacle course layout.
Then out to move the cabs that need to be cut up for scrap... hey... Travis discovered if you tow one across the field at 30 mph, it catches air and does flips... why not race while doing it?
Still not small enough... lets do a cab pull-off using the 2wd's.
Still not flat enough...
Look at that flex:
Maybe we shouldn't have set off a "firework" inside one of the parts trucks that night.
Why did I do this?
Ok... so it was after dark and we couldn't do any work anyway when I got stuck... but the 3 winch retrieval process took up valuable daylight time the next morning.
I spent my breaks from work going up the road to pull out the 2wd Datsun... at least 4 times.
Coming soon...
My illegal load of scrap metal.
hummm tough call, its work to set up fun yet it dose look like fun, but i am sure something was acomplished, dose look like fun wrecking some stuff, but wate all fun stops and its only stupid work after you get good and stuck like that. so lets see you money sucking load of once apone a time truck cabs.
[ QUOTE ]
I dig the living room furniture.
[/ QUOTE ]
hey skelly you are close check out
socalbigdawgs.com /forums/images/graemlins/bow.gif
Is that the same Datsun that had the big tires on the rear? Looks like it took a turn for the worst.
