Doing a 454 carb to 454 TBI swap.
87k5
Registered Member
Columbia SC
Hello to all,
I need some information on doing a motor swap. Here is my situation.
I have a 1988 CC that does not have the original motor with it. It is carbureted 454.
I have purchased a 1989 suburban with an original 454tbi installed. That motor has all the smog components installed. I have no interest in running a smog pump. If I decide it remove the smog pump, and associated components, will the ECM be able to control the engine correctly? I guess my question is: does the ECM have anything to do with the smog pump; are they in any way interlinked?
I’m sure I will have more questions to follow but I will start there. Your help is much appreciated.
Thanks,
Charles
There is a setting in ECM for minimum temp for air pump, wire on pin C2... but no DTC, so no issue removing it.
Thanks for the info guys!!
What does DTC mean?
Thanks,
Charles
Diagnostic Trouble Code aka Error code, the number that goes with the Check Engine Light.
