Don’t tell Wife how much this is gonna cost
84 Jimmy, 383, 700R4, hunting rig
84squarebody
Spokane
See the Image Gallery Tab you noobs
37ddc97a-beb7-4587-8bd0-ed80d72c736c-jpeg.248619
Looks real good. What size tires and what axles are you running? What else do you plan to do with it?
I put in Yukon Gear 4.56 Heavy Duty gears axles etc. Bow tie Overdrives 700R4 and a 383 stroker supposed to be putting out 450 Horse but I’m not sure, it is fast but I don’t think it is 450 Horse fast! I put 33 inch Dick Cepek tires on the original rims and had them powder coated. Now just need to get everything dialed in and start on interior and paint!
Looks great.
On the 4.56 gears, How many RPS are you turning at highway speeds (65 - 75 range)? I'm deciding between 4.11 and 4.56 and have similar size tires. Running a 4L80e.
there only about 200 rpm difference at 65 between 4.10 (mid 1900) and 4.56 (mid 2100), I run about 2250 with 32" with 4.56 at 65
4.56 at 75 2503
4.10 at 75 2250
Put on 35’s, looks like you have the room, you’ll be good.
