There is a dimple in the upper door frame that is counter sunk for a screw that holds the vent window. Is there a tool to make this dimple in the door frame?
A 3/8ths ball bearing and a hammer. Hold the ball bearing with a pair of needle nose vice grips, give her a little love tap, repeat until you get desired dimple.
This is the best quality made in the USA dimple die available. The 3/8” Crater Maker is the first product developed by Hammerfab back in 2014. It is CNC machined from 4140 alloy steel and then heat-treated for hardness. Install with a hydraulic press, bench vice, or an impact gun using the nut...
