Door disassembly
madups311
VA
Help I am taking apart my door to bang out some dents, and what is holding me up is the window roll-up lever and can't figure out how it is held in there?
There is a clip between the handle and the door panel that holds the crank on the splines. They make a cheap tool that pushes it out and it can be found in most parts stores in the 'Help!' section.
Rene
yeh i've got one of those they are real cheap it's called a rag/forums/images/icons/smile.gif. hhehehe turn the handle so it pointing down they take a rag and work it up behind the hand all the time you are pulling it back and forth, just keep a eye out for the clip somtimes they come shooting out.
