Are you sure all the screws have been removed?
THere's a line of screws on the bottom and 2 screws in the armrest, then the only thing holding it is the plastic ribbed pop-in pieces, so you just pull and it pops out. You usally have to pull on the bottom edge, get it all loose, then lift it straight up off the window edge, the inner window weather strip is attached to the door panel.
