luskeyclassics402
Registered Member
What doors from what trucks would fit my 88 k5? Would the pickup doors fit and what years?
doors from a ford prius wont work![]()
is there a really good way to check them? the original ones are bad i can tell hanging on the truck but how should i go about checking the new ones
Ok cool thanks!
No problem. Go look at your k5. Look where the hinges mount both on the doors and on the body. Mine are cracked a little and my doors dont line up for $hit. But my hinge pins are worn out as well.
You should definately mark the hinges with some lines with a paint marker or sharpie to allign them up when reinstalling. I would put one on the top of the hinge running vertically, and one on the side running horizontal. Then when you line them up you know its dead nutz where it was before. In your situation because you didnt mark it........ $hits focked..... Lol jk, but you will prolly have to just keep playing the loosen, move, tighten game.
Sorry man im out of ideas. Only really messed with doors on my bronco ii. And those lined up fine by myself using 5 gal bucket to hold the door up. Just order some tube doors from DIY4X![]()
