sled_dog
1 ton status
that was the thought with the idler arm setup, thats why I like that design. Wish I hadn't covered up the holes on the frame of my s10 I could have run the idler arm setup... oh well.
sled_dog said:right off ORD's site...
Why not use a 2wd Steering box (or just the 2wd sector shaft), pitman arm, center link and idler arm? Run a drag link from the passenger side on the center link to a steering arm on the driver side.PsychoticDeadGuy said:edit: Anyone get the new Peterson's 4wheel and off road magazine? there is a steering article and they talk about different crossover steering systems. the double crossover has a link from the steering box that goes to a bellcrank on the other frame rail and then from there it has a link that goes to the driver side knuckle with a tie rod. you wouldnt need the flat top knuckle for the passenger side at all. how wouldw you set up the bellcrank system on a K5? what kind of truck could i find this type of set up on? any one ever do it? oh, and the reason i am asking is because i want to do a cheap crossover for my 10b until i find a d60. and i cant find a flat top knuckle for the passenger side.
richheezee said:Why not use a 2wd Steering box (or just the 2wd sector shaft), pitman arm, center link and idler arm? Run a drag link from the passenger side on the center link to a steering arm on the driver side.![]()
nope, no pics or input... sorry. i am picking up those exact parts this weekend though.PsychoticDeadGuy said:thats what i wanted to do. i wanted some input on it though...i wanted to see some pics on how to go about doing it...kinda....but do you have any pics of something like that?
except the steering arm.
Check out some jeep sites they call it a z link and there not very much money.PsychoticDeadGuy said:wow, i was gone for a few hours and this thread took off. i like the idea of the drag link in that pic that was posted. what if i made a link that was bent so it would clear the leafs or tie into the tie rod without so much angle on the joints. will regular tie rod ends work for this? would i need to weld some brackets onto the tie rod to bolt the drag link to or how should i go about doing this?
