Double flare tool
Mastiff
Tucson, AZ
So I bought a cheap double flare tool at Oreilly. I got out some scrap to practice (3/8" fuel line) and it absolutely refused to do step #1 without just pushing the line out the bottom of the flare bar. I surfed around just a bit and saw a post like "make sure the line isn't metric, because it can be just a bit smaller". What I'm working with is fuel line with the Saginaw fitting end for the TBI system. This seems to be a hybrid of metric and english. It takes english wrenches, but adapters to it are called 16mm (IIRC). So, do I need a funky metric flare tool to do this?
Just so this doesn't go off track, I'm really just trying to make a "bead" to attach a rubber line. I planned to just do the first step of the flare. In addition to using the tool as designed, I also clamped it into a vice right next to the hole I was using in case the bar was bending. Still no dice.
I ran into the same thing. If you are just trying to add a hose flair, get it red hot, put it into the flair clamp, hit it with a center punch.
Wouldn't it still just slide out, or are you saying the red hotness makes it soft enough to bend before it slides?
Yep. I had the clamp slightly loose with the tube sticking out. Put the tube in the vise. Heat the end. Let the tube slide into the clamp. Tighten vise. Center punch.
the one they have for sale sucks..... rent the one that they have, its a MUCH better tool. I had the sliding issues, and broke the center pin off the 2 smallest anvils in the set, then just went and rented the one they had for loan and it was a night and day difference... ended up buying that one.(didn't take it back and they just don't give your rent money back)
Yes. I returned the one I bought and got the loaner. Worked like a charm. Goofy thing about it is that the loaner is $24 vs. $20 for the one I bought.
that's why I just kept it:rolleyes: guy told me to if I liked it
