So I bought a cheap double flare tool at Oreilly. I got out some scrap to practice (3/8" fuel line) and it absolutely refused to do step #1 without just pushing the line out the bottom of the flare bar. I surfed around just a bit and saw a post like "make sure the line isn't metric, because it can be just a bit smaller". What I'm working with is fuel line with the Saginaw fitting end for the TBI system. This seems to be a hybrid of metric and english. It takes english wrenches, but adapters to it are called 16mm (IIRC). So, do I need a funky metric flare tool to do this?
Just so this doesn't go off track, I'm really just trying to make a "bead" to attach a rubber line. I planned to just do the first step of the flare. In addition to using the tool as designed, I also clamped it into a vice right next to the hole I was using in case the bar was bending. Still no dice.
guy told me to if I liked it
