wasted wages
1 ton status
I have a T-400/205 I would like better overall gearing reduction..
I have looked into NWF/offroad design doublers...
And the Stak / Lowmax boxes....
what are some of the advantages / disadvantages of each ?
The way I see it is...
with the doubler....there is lower cost...but....I would have to find a 203 box and adaptor...as well as the doubler kit....rebuild everything,,, including having the rear drive shaft shortened and build a crossmember to support everything...the front shaft will be ok...square tube drive...
with the stak or lomax...everything would pretty much be a bolt in deal...but have an initial higher cost.....without much modification to the rest of the buggy...so it may just be a wash......
so...is the final crawl ratio's the same ????
or does the doubler win out in overall reduction ratios???
what say the brotherhood ????
