Metal Twister
I just acquired a factory air AC unit, something I have wanted for years but never really got into. I also have a York installed now that is being used for OBA. So the question is... Id like to double up the York's... one for the AC and the other for the OBA. Any issues with running them off of the same V belt? The engine is a fresh 350 and I personally cant see any issues. The OBA is manually controlled via toggle switch so I can make sure only one is running at any give time. Would there be enough of a drag to make a difference if they both were on at the same time? Or only if they both started at the same time? Any insight would be appreciated.
