draglink help
73redblaze
Aptos ca
i bought the ballistic fab crossover kit and the tie rod works perfect but the draglink hits the leafs. i dont think i have enough lift. im running stock 56's up front. is that why they sell those bent draglinks? can i use my rod ends on one of those bent draglinks? please help:confused:
i didnt take a pic. but this one connects to the tie rod hole not your knuckle
it is suposed to look like the 2nd pic but it does not connect to the knuckle so it wont work
yeah that setup not so much for leaf rigs.
I dont see how you could make that work. i had my old setup off the tierod, but it was level with the tie rod. this one is above it, so im pretty sure no matter what its gonna hit your springs.
hay chris do u need me to post up a couple pichs of the cross over steering bought off of u? and 73redblaze if ur needing me to i can build u a set up like chris' old set up for basicly the cost of the parts.
this is how mine was bent, but will not work with what you have. It would occasionally rub the leafs, with yours higher than this its gonna go straight into the leafs.
oh ok thanks for the pic. i took it to a fab shop and they are going to put a 6" bend in it for me. its a quick fix and im happy
Why not get the correct passenger arm for your front diff and do it right? Cut corners on body and paint...go for it. Want a cheap stereo? Cool. Cheap/scary steering? I gotta say something.
Rene
