CGT80
I have finally started to use the milling machine more, that my dad and brother have. It sits in the garage I use. It is just a cheapy harbor freight vertical mill with a round mast. With a decent chuck it is an awesome drill press. I do some milling on occasion as well. I think they picked it up for $600 bucks used and then swapped out the 3 phase motor for a 2 hp baldor 220v motor. Now I wish they had used a VFD instead, so that the speed could be controlled electronically and mechanically.
I know it is probably outside your budget, and the milling machines are pretty big compared to a drill press, but I never knew how much I could utilize a mill. I have a small benchtop harbor freight drill press. It is ok, but bigger is better...........it is easier on the user and cutting tools to use a machine that has the right speed, torque, and downward force.
