Drive Line
Montanachris
Registered Member
Huson, MT
Looking for the correct rear driveline angle for my 72 blazer. Currently it is at 23% with a 2.5” lift
2 styles of driveshaft. Cv at or singe u joint at t case, which do you have? Ea style uses different methods.
yes you want the 2 angles to mirror +- 2°. Do not shim your t case cross member lower. Do so only as a last resort.
