Drive shaft vibration/transfer case drop
prolinews
Georgia
I installed a tuff country 3" lift kit on my 88 k5. The kit came with a 4" tapered block for the rear. I'm guessing to correct the angle. I have a slight vibration at low speeds now. I am thinking that if I drop the transfer case 1" it'll help get my angles back right? I was hoping that I could avoid all this with a 3" lift. I have to take it to the muffler shop to get the exhaust ran different because the y pipe is 1/8 " below my front drive shaft. Will this get me in the ballpark ? I have read a bunch of threads where people say don't do a transfer case drop and read a bunch where people solved their problems with the drop?
it's a bandaid that screws up your front shaft angle worse.. check your current angles with a magnetic angle finder to figure out what shim you need..... make sure your u-joints are ok.. changing the operating angle will show a u-joint heading south in a hurry...
Okay I put a angle finder on the tail shaft 2* and put one on the rearend got between 9-10*
Correction the tailshaft 2* down the drives haft 12* the rear pinion measured 5* on the bottom of case it's hard to measure on the snout because angle finder is a little bit too long to fit flat
I think you'll need a 3-4* shim in the back. That way the snout is parallel with the tailshaft. I say 4* cause cause that will put you 1* lower, allowing a little bit of upward rotation during acceleration.
I'm sure I'll be corrected if I'm wrong lol. If you can have someone tapper that block for you, it would be better than adding a shim. If you can't, maybe get a shim made of the same material and weld it to the block. (after you are sure it helped)
Am I trying to achieve the same angle on both the snout and pinion? This stuff is all new to me.
as mentioned, the axle pointing a degree or 2 lower is fine.. allows for axle wrap.. but generally, they should be pretty equal...
Also I guess with shims I am rotating the pinion down in the front?
Okay it's starting to make sense to me so theoretically if I had zero angle at tailshaft I should have zero angle at pinion?
Okay it's starting to make sense to me now , I measured it over and over again and pretty much think my tailshaft is between 0 and 2 and the rear pinion is definitely 5 so I need at minimum of a 5 degree shim but preferably a 6 or 7? Where's the best place to order shims?
As it sits now, does the axle yoke point AT the end of the tailshaft? Meaning, if you draw a line like the above picture, through the axle, does it point directly at the end of the tailshaft?
If it does..... forget shims and go straight to a CV shaft. All problems or any future problems are solved :) Everyone goes to a CV shaft sooner or later. (some exclusions apply)
I just couldn't be bothered to go back and quote it... CV is overkill for a 3" IMO.. unless yeah, by some chance it's aimed perfectly, than it would be worth the coin to change the shaft setup...
I got a couple pics to make sure that I'm looking at this right
The block is higher in the back and tapered in the front rotating the pinion down.
you're taking pics WAY too close.. we need to see what your measuring in relation to the driveline...
