Driveline angle problems
3 options I can think of..
1) shims under the leaf packs
2) a high angle shaft
3) cutting the spring perches off, rotating the axle as desired and welding the perches back on
j
[ QUOTE ]
Or you can drop the x-fer case.
[/ QUOTE ]
doh!!! forgot about that. Still, the guys rig is lifted so I figure it might get wheeled, better to keep that stuff up nice and high. /forums/images/graemlins/wink.gif /forums/images/graemlins/laugh.gif
j
Driveline angles driveline schmangles, who cares. hehe. The vibration doesn't start getting too bad until your pinion points up higher than the driveshaft like mine does:
At 72mph, you don't even have to stir kool-aid, the truck does it for you. /forums/images/graemlins/rotfl.gif
I recommend shims. Someday I'll fix mine.
Mine is just like that...slightly negative. No vibes for me...guess I'm lucky. I'll fix that one day.
