Just install rear zero rate from ORD. Pinion looks to be even with transfer case. Looks like maybe more drive shaft is hanging out of transfer case. How much shaft should be in the transfer case. Gonna pull shaft tomorrow and check u joints.
Don't really want to drop transfer case, but will if that's the fix.
What have you guys ran into. Did not think a 1 inch lift would do this.
Yes a have searched,
Thank you
Thank you
