ccarley
Ever since replacing my trans and trans mount, I've got some crazy vibes going on under the truck. Feels like U-joint to me, but I want to describe what I've got going on and see if anyone can say "yup, that's it!".
***I will be replacing both U-joints on the rear shaft today***
So, after fixing the trans and replacing the trans mount, I had a vibe coming on at 50 mph, and worsening at 55 mph. Guessing it was U-joints, I replaced the one after the transfer case, as the one at the rear axle was new, and it was visibly worn out. During replacement, it is possible a needle fell as it was tight in one of the yokes. It felt like it was OK, but it's hard to tell on a lot of the farm roads out here.
Now, it is getting worse again. My wife describes it as a chair massage at 50 mph (I call it a grumble), and it is almost scary at 55 mph.
First thing to check is U-joints for this issue, yes? Would driveshaft angle cause these types of vibes, or would that cause different symptoms? The driveshaft could be out of balance, however I didn't have this issue before, and we are always careful not to beat it or bend it
Truck is a '89 Suburban, with 4" spring lift.
Again, I'll be doing the U-joints on the rear shaft today, to start things out.
Thanks,
Clay
Thanks,
Clay
