So I have this vibration at 30 to 35 mph. Goes away on the hwy but is really bad on residential streets. I have search and most of what I have found is when you do not have a rear CV. I have a rear CV so I am at the glorious K5 brick wall.
Specs:
350 motor, 350 tranny, 203 full time (no PT kit) , 4" lift- springs in the front block and AAL in the back, 33x10.50 TSL radials. Its a mall crawler I know!
Whats New:
New front drive shaft with CV
New rear drive shaft with CV
New T case mounts (Energy Susp. Poly)
New motor mounts-Autozone nothing fancy.
Could it be the pinion angle?? I'm not sure it is, as the vibs seem to be at the front of t case? Could it be the t case chain? Not sure its the shafts being out of balance either as they are new and came from a highly recommended company in AZ. I did run in HILOC with just the rear shaft for maybe 20 miles just to the line x shop and back and was really bad. Improved greatly once I got the front shaft on. I drive it just fine but it can't be doing something any good!
Is it me or is this normal? I would expect this if I had more lift.
Thanks for the help and advise in advance.
Dave
Specs:
Whats New:
Dave
