driveway cleanup
COCHEV
Washougal WA
What do you guys use for wet clean ups on isle 6?
More particularly, I degrees my engine most times when I'm done working on it. Well out here in rainlandia I end up with white milky driveway runoff and shiny rainbows after that.
I'm just waiting for someone to call the tree hugger police on me...
Suggestion...:dunno:
Purple power works great for those big stains, for a regular maintenence type thing I usually use laundry detergent or even dish soap that's good at breaking up GREASE. Spray it around, use the garden hose to wet the area alittle and then a shop broom all around scrubbing the area. You will always get the rainbow coloring when it rains, you're never going to get it all out of a concrete surface.
Usually comes pretty clean, and the more you do it and stay on top of keeping the area clean, the cleaner it will get over time too. :D
For wet cleanups I use cat litter, sawdust, or powdered detergent + Simple Green.
Once it set in it is another story.
When I was in the military base housing, any drops of oil, or stains were a huge deal. I tried laundry detergent, degreasers, gasoline etc to get the oil stains out to no avail. I tired "Pour-n-Restore" http://www.pour-n-restore.com/oilstain.htm, it works excellent, although it is very expensive....
