Got a little air going up the stairs.
Yup, a little more than I wanted...
I blame it on the missing shock on the passenger front side. The seal let go on the short one of my quad-5125 setup somewhere on Golden Spike, and I removed it so as to not leak oil all over the trail.
Turns out the shock is 'factory-rebuildable' - which, incidentally, costs as much as a new 5125
. But the quad-5125 setup was a temporary solution anyways, workable and better than the single 5125, but only until I would be able to make up my mind what I want to do re shocks. Back to the drawing board, for now. The rear has RS9000XL adjustables, set for '9' on the trail, and it feels I could use more shock there as well.
The right rear corner is a bit worse for wear...
But I guess the good news is that the traction bar is still on the truck...
I'm mulling over either getting a new rear bumper, or cutting the carriers off of this one. I think I'm done with having to swing away the carriers every time I want to open the tailgate.
I can fit the 35" spare inside easily, and I'm tired of the jerry cans and their low 'flow rate'. Since I now have a decent 12V connector in the back, I think an electrical fuel transfer pump back there would be the ticket, possible together with a 12gal polyethylene tank originally designed for a boat... or maybe just a fuel cell.
