Stomis
Professional Amateur
Well crossover is just way too much money. Where can I get a drop pitman arm to correct the 4/5" of lift I have on my truck?
My bad, I read your first post as if you had a 4/5" lift (i.e. .8"). I guess that's the engineering school talking
If you have 4" or 5" of lift, a drop pitman arm or raised steering arm will help.
I would use a raised arm instead.Raised steering arm would be better for you. Its cheaper and closer to your amount of lift.
A drop steering arm is advertised at 2" but is actually a true 1.5" drop. Only Skyjacker makes them. I have bought a few from them and they go for around $75-$80 before shipping.
Stick with the raised steering arm. It will get your drag link closer to level than the pitman arm will.
