Drop the Drag Link, and Step Away...
1-ton
3/4 ton status
Las Vegas, Nevada
It has been brought to my attention that dropped drag links are not the best way to go, in order to correct the increased drag link offset created by lifting a vehicle. I have a 1-ton truck with a Dana 60, 4" of lift, and a 4" drop drag link. I need some ideas on what way I should go about loosing the dropped drag link, and where I can purchase the parts needed to replace it?
It has already been suggested to go with a raised steering block, and or a combination of dropped pitman arm and a steering block. I have shopped around the usual places on the Internet for a dropped pitman arm, but I could not find any for a Dana 60...only 12 bolts and Dana 44. Does anybody know of a good source for a dropped pitman arm, or raised steering block for a Dana 60?
I bought my steering block form 4 wheel parts.
I will have a steering block for sale in the next month or so /forums/images/graemlins/whistling.gif
Drop pitman arm has nothing to do with what axle you're running...it works for all of them.
Skyjacker CA50 is what you're looking for and yes I sell them. /forums/images/graemlins/thumb.gif
I also have a 4" lift on my 1 ton, and I use ONLY a dropped pitman arm from Skyjacker IIRC, and it works flawlessly.
Does your steering block happen to be a Skyjacker part #SB60 with a height of 2.5"? Skyjacker also appears to have a dropped pitman arm part #CA50 with 2" of drop.
So all I need is the 2" pitman arm, and the stock drag link?
[ QUOTE ]
[/ QUOTE ]
How much do you want for one of those?
avoid the off the shelf steering blocks
they suck in the spring spacer area
fits like a dick in a shirt sleeve
[ QUOTE ]
[/ QUOTE ]
Mine fits just fine. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
[ QUOTE ]
but you're little, so you have little sleeves. /forums/images/graemlins/rotfl.gif
[/ QUOTE ]
My point exactly. /forums/images/graemlins/histerical.gif
And BTW, your sister never complains. /forums/images/graemlins/waytogo.gif
hmm this one can go either way...
she prolley never noticed ya there
[ QUOTE ]
[/ QUOTE ]
Yeah well I was pokin her belly button.....
on the local board you would be required to post nekkid pics (of HER!)
<drool> belly buttons
/forums/images/graemlins/yikes.gif
[ QUOTE ]
[/ QUOTE ] /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
