I converted my '67 14-bolt FF to discs using bracket made from pattern off eBay and using 3/4-ton rotors and Eldorado calipers. This made the conversion very inexpensive.I did have to change brake master cylinder but proportioning valve worked fine despite some people saying they had trouble with those when making this swap.
Does anyone know of a similar "swap" for 10-bolt rear ends? Something that uses OEM parts with a homemade bracket (and where to get prints to make brackets?)
Thanks in advance! trukman1
