DRW Front 60 to Single Wheel
LIVEAnimals
Wheatland, CA
I found a guy on CL parting an early 80s 1 ton DRW Chevy 4x4. If I was able to get the 60 for cheap what and how much would it take to convert it to single wheel.
we have a guy locally,, I am sure you can find one in location, he can turn the hubs down, knocking off the "dully " part of the hub, leaving a clean smooth surface, the dully hub and rotor are bolted together, you need to drill that a out one size bigger to accept the single wheel studs,,
