Oh no! You just proved that my system doesn't work. Maybe my truck still starts because it doesn't know any better?
Let me tell you how it actually works. There is load sharing. Of course it is not even, but why does this matter? At lower loads one will deliver more current than the other. As the load increases, the voltage will drop until both alternators are at maximum output. One will probably last longer than the other, but even the one carrying more load will still last longer than if it was running as a single. You will run two stock alts of the same style, so they will have similar characteristics, which helps them to share.
Here are the advantages over a single high-output alternator:
1) cheaper. You already have one and the second should be less than $50 with cables and some junkyard brackets. Have you priced high-output units?
2) More current at idle. You don't get 140A from the high-po unless you rev the engine way up. Some high-pos actually deliver less current at idle than a stock one. Running two clearly doubles your idle current capacity (which is usually the limiting factor that makes you want to upgrade to begin with).
3) Reliability: Aftermarket alternators can be finnicky. Even if you lose one stock one, you can still drive. You just can winch as much or run as many accessories. Then you can pick up a replacement at ANY parts store (or junkyard) instead of special ordering. In fact, you will be able to get a new one for free from the lifetime warranty (this reinforces #1). Reliability is enhanced even more if you set the two up on seperate belts.
The only drawback is that it consumes more space underhood.
