Kenny78
Again, Ryoken, you are the man on 12V. I kept wanting to say drum switch, but it just wouldnt come out right. I should prolly stop grasping and just use more relays.
I know I'm late to this party but I am noodling out my setup and I expect it will be similar to the above. I have a (dumb) question, though - what function is the slave solenoid performing here? Also, what P/N is being used? Is "cab feed" an ignition hot?you can take your excite lead right from the main charge post on the alt... just piggyback it...
here's my 1/2 done diagram of mine.. the red circle is my marine switch. the blue circle below it is the ACR, the orange wire coming off it is the parallel trigger running into the cab to a parallel switch......
you can use either bank as a primary with the marine switch, both charge all the time as needed due to the ACR.. they can be paralleled with either the parallel switch from the ACR or by putting the marine switch to all...
the slave solenoid is what many refer to as the "remote Ford solenoid mod"
the slave solenoid is what sends juice to the starter when the key is put to "start"... thats what the "signal" wire is for, fires off that solenoid when in the crank position.. it's just a continuous duty solenoid... most guys run 90 amp stuff from napa, etc for about $25.. mines a 450 amp bluesea version..
cab feed is not an ign hot.. it's the power feed to the cab, hot all the time.. it does feed the ign circuit.. thats what the cab breaker is for..
that relay bank is fed from multiple sources, depending on the relay... theres 6.. hi beam, low beam, 2 for fans and 2 for the volt gauges..
one of these days I'll finish that diagram..![]()
