Looks like you will need to unbolt that upper outside mount and re bolt it in the original holes moving it closer to the frame. The bottom one, the shock will go in the middle of the mount not on the outsides of it. That upper mount may of been changed from stock (Longer) for the dual setup If it is too long I have some stock ones laying around.
There may be a bit of pressure, but shocks move slowly, especially old ones. You don't have to worry.And... When I remove old shocks will they be under pressure/load? Do I need to worry about losing an extremity?
