Bubba Ray Boudreaux
1 ton status
As you can see here, the bottom of the shock is mounted with the eye perpendicular of the axle and the top is also like this. This setup won't be binding at the mounts when one side of the axle is up and the other is down.
I will be copying this setup once I get started. The pic is from a hot rod Class 3 K5 that was raced in AZ a few years ago. Throughtout my travels, I've noticed the same setup on straight axle rigs in the desert, and you will see this alot on the rearend of the geriatric crawlers around these parts.
