Dually axle.
Brocky
St.John's Newfoundland, Canada
I was in a local junk yard today and found a few old 4x4 tow trucks. I may be stupid in asking but what in envolved in turning a dually axle into a single wheel axle.
all depends on what the axle was out of, how wide the WMS to WMS is, and what the backspacing on the wheels is.
yes you can
technically the drums are different, but you can still bolt singles on a dual or the other way around, if your spring packs will clear
If its a non C&C (cab and chassis) 14 bolt, then you just have to swap brake drums to make it a single wheel.
