Dually to Single Dana 60 Conversion
Hey manch65, any chance you can find a part number for that assembly because I can't find anything close on gmpartsdirect.com. I would rather just sell what I have and do what you did. Thanks!
all you need to do is get rotor set on hub unit. then press in 8 studs. then repet for other unit.
but might be faster and easyer like you want to open box and install.
A part number would be great if you still have the box. I am pretty sure the website is.
gmpartsdirect.com
but having a hell of a time finding the hubs in their catalog :doah:
Can you clarify this a little bit for me? If I get a set of rotors for a srw D60 and 16 studs can I just press it all together? Is there a piece that goes between the rotor and the hub? (it looks like it in the picture)
3 basic things make up a hub/rotor unit.
1 rotor + 1 bearing/hub unit + 8 studs + set rotor on hub unit and press in the studs and you get a hub/rotor unit like in the pics.
fyi tho if you are thinking of 15" rims on a 60 front. if you are buying rotors now is the time to do a 3/4 ton rotor and brake caliper bracket swap. thay have kits for dana 60 to run a 3/4 ton rotor and new caliper plate bracket and use 3/4 ton calipers. this lets you run vary comon 15x10 rims with 4.25 backspacing . this would save you over the rare expensive 15x10 2.50 backspace rims.
just a idea for ya.
links :
http://www.blackbirdscustomtrucks.com/index25.html
scroll down a bit pic and info for it.
Do you have a list of the parts with numbers that you purchased from gmdirect?
I dont think they have them anymore .
Hillbilly wizard is a vendor here in our vendor section . He just listed up hubs for sale .
