GonicGM
Received my 1987 V3500 dually with dump body installed. Will eventually put a dually bed back on it. Meanwhile it has this dump that works well and will be handy for now. Upon servicing and greasing, I found a spot of concern. It is the lower pivot point attachment for the lift cylinder. It is part of the sleeve that wraps the attachment tube that bridges from frame rail to frame rail. I would term it as a bump stop but I'm sure the term is incorrect. It's not grass but appeared as such. A bunch of tightly packed grass. It's in the cavity forward of the tube and rear of the three vertical studs. There appears to be little left of what I believe was originally there.
Can anyone enlighten me, trade term, function, where to buy replacement?
