B.N.Z.MTNS
Elevation 8,500’
Hey guys,
I have been searching for a while on here and see lots of great input, but have not found anything regarding longevity.
I have a 2001 (LB7) crew cab DRW, 4WD with about 215,000 miles on it. It spends most of its time running errands for feed and supplies and about 40% of its time pulling a hay trailer or our gooseneck trailer. We live at 5,700 feet elevation and regularly pull passes up to the 10,000 range.
To date it has had:
- injectors done at 97,000 miles (at GM)
- water pump at 180,000
- fuel pressure regulator at 205,000
- Kennedy diesel ECM (100 hp / 150 tq)at 207,000
- Replaced all pitman, idler, drag links twice
- U joints and carrier bearing once
- Regular service with synthetics every 3,000 to 5,000 depending on use
As of now I am experiencing coolant loss, but I cant track it down. I add about 1/2 gallon to the reservoir every month or two but there is no external evidence and no dilution in the oil. It runs like a top still, so I just keep adding coolant.
I am curious what longevity any other first gen Duramax owners are getting before having to consider a rebuild or replacement? I am debating a newer (2008 and up) Duramax, but shelling out that much cash again is daunting, plus the newer ones have the particulate filters and I hear they get worse mileage.
Any input or advice would be great. You all have been awesome on the K5 end of things and now I am looking for some expertise in the high pressure world.
Thanks,
Brian
To date it has had:
Thanks,
Brian
