Easiest way to install ORD greasable busing in front springs? *DELETED*
Re: Easiest way to install ORD greasable busing in front springs?
I'd like to do these this weekend, so any tips/help is appreciated. I know a bunch of members have done these, right?
It's really just as easy as taking out the springs, pulling out the old poly bushing, and greasing up and sliding in the new ones. When i ordered my 6" TC springs years ago i also ordered the greasable bushings from ORD and you know what i found out, the poly part of the bushing is exactly the same, TCs come with the exact same poly bushing, same part number molded in, same everything the only difference was the bolt and sleeve which allows you to grease it. So i have an extra set of poly in a box in the garage.
