Looking for some ideas for the easiest way to do this job. I have some greasable bushings I need to install just in the front of the rear springs. Whenever I do this job it turns into a huge pain. Here's my bad technique:
1) Try unsuccessfully to jack the body to the point where the spring is not under load.
2) After getting close but not right, unscrew the bolt from the spring eye and let it pop into whatever position it actually wants to be in.
3) Replace the bushing.
4) Try to jack the body into line with the spring but it doesn't line up. Foolishly try to move the axle forward or back
5) Cuss and complain while prying on the spring until it lines up close enough that a punch can be forced in.
6) Cuss and pry some more until the bolt is close enough to be able to be BFH'd or screwed in.
7) Be certain there must be an easier way.
The one easier way I can think of is to fully remove the spring from the axle, is that the ticket?
