BowtieBlazer
Diesel Powered
88 355TBI
One morning this week I got in my truck started it drove about a tenth of a mile to the gas station shut the truck off went inside came back out bumped the truck over and it sounded like it was going to crank so i let off immediately and then i heard a pop from the fuse box. IGN fuse was blown I put a new fuse in turned the key to ign on not even the start position and each time i would it would blow the ign fuse. I then found that two of the three wires going to my 02 sensor were touching the drivers side header. Separated those two and then it stopped blowing that fuse but would not start despite the starter rolling the motor over. I bought new wires to replace the two burnt ones and splice them in. No change and now i notice no fuel. I decided it was the ign cont. mod and walked down to napa and paid the $73 they wanted for a new one off to work i go....
fast forward to that afternoon, i hook to a 8x12 enclosed trailer to drag home for a friend of mine and hit the road. 60 miles into the trip on the interstate doing 70 the service engine soon like comes on momentarily the truck sputters then the light disappears and the truck resumes running fine. 20 miles later i get onto some broken concrete sections on the interstate hit a good bump that jarred the cab and the light comes on then the truck engine dies i shift to Neutral and crank with no luck of restart, get towed off the interstate and to a friends house decide it the module again goto advanced auto get a new ign control module replace it and the remote starter solenoid i mounted on my firewall to help with the heat soak problem i was having incase the contacts in that were getting crusty and opening the circuit. drive 70miles home uneventfully and another 120 since then.
I am looking for diagnosis to possible causes the battery is mounted in a tray and clamped down the terminals are tight. I am replacing the battery cables just incase. eitherway if the hwy causes this what happens when i get offroad. By the way if your truck will not allow the injectors to fire and your service engine soon light doesnt come on before you start the truck its probably the ignition control module
