Kain
3/4 ton status
the one on the right in that^^ pic is where i hooked booster to
Well that's crappy! Doesn't make sense to me.
The fitting in this picture may not be the one that I kept, don't remember.
I run mine out the port on the throttle body too. However, I purchased some 11/32 hose because I wanted a tighter fitting hose for the PCV and brake booster anyway so I didn't notice the fit being a problem. I still add the spring clamps too. I also used 5/32 hose instead of 3/16.Where are you guys connecting your booster vacuum source? I have two nipples on the back of the throttle body, both are too small unless I run some sort of reducer fitting.
I used the threaded port in the runner for transmission and the AC/heater thingy that's mounted on the firewall shaped like a sphere.
I'm still cool.I put a divided gasket on. If you remember back from your Holley Sniper days when we were cool, they said that was the main cause of whistle on the intake
I had to use a 4 hole gasket on the Sniper to stop the noise, but it was happening anytime the throttle blades were opening on that one. The PF4 is only at 25%-30% throttle position.I do have a dual plane under the Sniper. It's the Weiand 8122 made specifically for the peanut port 454 heads. I know there's been discussion about single plane intakes for the TBI type EFI, but mine idles and runs great.Was yours a dual plane intake?
Yeah I forget that whole open plenum thing. Thanks for correcting that!I was referring to the divided gasket which was suggested, I think a divided gasket would be worse with a single plane intake because there is nothing there to sandwich the gasket.
