Thats just one example and it really depends on the engine. I'd rather have more HP/TQ for going up the 6000+ feet mountain passes with the heavy 40" tires.
Another I found with a Hemi. I know its a totally different engine but interesting to see some real numbers.
quote-
Just finished dynoing Bill Hall's 06 300C Hemi. Only mod is Dynomax cat-back. Honestly didn't think the t-stat would make that much difference. How wrong I was! With the car completely warmed up it made 284rwhp & 323rwtq. While still on the dyno I changed the stock 203 deg t-stat to a 180. Started and ran for a few minutes. Not up to full temp and made a pull. The car responded with 306rwhp & 351rwtq!! Did another pull and it almost laid directly over the first (about 2-3 hp less). Finally, with the car completely up to temp it made 300hp & 334tq. IMO, great mod for the $. I used a Napa 191 t-stat and drilled a small 1/16" hole for an air bleed facing up. Hopefully we'll have tuning software at the begining of January and can really fine tune these cars/trucks. I'll try and post the graph this evening.
quote-
It's hard when stuff like that happens because you normally don't pay that close attention to it and then something happens and you question if it always looked like that or is it more/less/different.
