That’s what I did on my k5 before the broflow, just remember to adjust fuel pressure when you change altitude. Sea level to Moab makes it run pig rich.lolA TBI pump will be fine. They are designed to feed appx 10-15 psi, though they will deadhead much higher
regulator on the return, set it to appx 6 psi
Weekly fill-up on a 20 gallon?I do get nervous too. I had to trail run the crew cab for a while with a single 20gal saddle tank. Only ran out of fuel once and that was on a long day if snow bashing. That did motivate me to get the other tank operational.
The daily driver c10 has a single 20 gallon tank. I never worry about running out of gas just have to do weekly fill-ups.
I only use it for the utility.Yeah I commuted in my burb for a few years, ouch.
Now that's a freakin tank !!! Anyone tried to retro fit this to a SWB 4X4 ?What in tank fuel pump would one use for a carburated engine ? My thinking a TBI pump with return to tank regulator ? thoughts ?
EFI tank for 87-91 suburban 40 gl.
Where do you put it?Now that's a freakin tank !!! Anyone tried to retro fit this to a SWB 4X4 ?
Hey Wes, where did you source this tank? I have recently started looking and have only been able to find unbaffled tanks.What in tank fuel pump would one use for a carburated engine ? My thinking a TBI pump with return to tank regulator ? thoughts ?
Rock auto is a great place.Hey Wes, where did you source this tank? I have recently started looking and have only been able to find unbaffled tanks.
Found one easily and ordered. Thanks!Rock auto is a great place.
Since they list blazer and suburban, is that for the 31 gallon tank only?Found this from Quantum Fuel Systems.
LS Swap Fuel Pump Hanger for 1973-1991 Blazer, Jimmy, Suburban, Performance Fuel Pump System, QFS-H882 QFS
Hello Ed,
8an feed line is 1/2", 6an return line is 3/8" we should have these back in stock in the next two weeks
QFS Support
View attachment 497230View attachment 497231View attachment 497232
31 gallons!Since they list blazer and suburban, is that for the 31 gallon tank only?
Thanks, I do not have a need for it yet, but just wanted to confirm in case something comes up down the road.31 gallons!
check it out @ www.highflowfuel.com
