Will you also eliminate power locks? The two came together, so there isn't a door panel that has the window crank hole and a mount for just the lock switch. It might be possible to just cut a hole for the switch, though.
I converted my power doors to manual, super easy and a direct bolt in. I left my power locks alone with no power, no difference to me over actual manual locks. I did keep my power mirrors though.
