Electric door replacement for hand crank
Massachusetts
I have a 88 k5 blazer. Can I swap the guts in the door to change feom electric to hand crank windows? Seems like I have to buy a new door.
Will you also eliminate power locks? The two came together, so there isn't a door panel that has the window crank hole and a mount for just the lock switch. It might be possible to just cut a hole for the switch, though.
I converted my power doors to manual, super easy and a direct bolt in. I left my power locks alone with no power, no difference to me over actual manual locks. I did keep my power mirrors though. :pimp:
