lak2004
I have the windstar fans in my blazer and the Jegs wiring kit with a 195* thermo switch. I wired it up just how the instructions stated but the fans do not come on unless I manually switch them. I am not sure what is happening but I know the thermo switch is good. This is how they stated to wire it:
relay: 30-Battery 12V
85-Thermoswitch
86-12V+ Ignition
87-Fan +
85-Thermoswitch
86-12V+ Ignition
87-Fan +
I think you nailed it because I havent grounded my core support yet and that is what the fan is grounded too. I just re-did the frame and engine grounds so they are good. Thanks! I knew it would be something simple, always helps to have someone elses perspective!
