electric fans
Just search here on Windstar fans.
yup. Don’t even duck around with it. You can get brand new fans from rock auto for less than $100 that move like 2300cfm or some crazy amount. And fit like they were designed for it. I don’t think I had to trim the stock shroud at all to fit the radiator. Just same bent strap to mount and done.
Another truck on Windstars!
I did trim the depth of my shroud a little because of the BBC serp setup made it a little close otherwise.
ok windstar for the win, i am gathering parts for a failer or swap with radiator(dont like plastic tanks)
I used a Northern aluminum radiator from Jegs....its awesome with the fans!
I have a brand new Windstar fans WITH the pigtails that I can make you a good deal on. I can get it shipped out to you if I can find the box.
Four Seasons Fan Assembly 75300
The fan setup was $103 new, plus another $30 in pigtail connectors.
I'll sell it for $80 shipped
Test Results:
left fan: 340ml= 13.3inches
right fan: 390ml=15.3inches
left fan: 60.3cmm=2129.193cfm
right fan: 64.4cmm=2273.964cfm
this was rated at 1935 RPMS
4403.157 cfm total......
I'm sure I will still have it. LMK if you want it later on. Slowly trying to get my garage cleaned of un-used parts.
What's the stock mechanical fan rated at? Electric is nice for the control and losing the parasitic loss of the clutch but I've never had great luck with them keeping stuff as cool as the stock fan.
rig never had a stock fan when i got it it had a flex fan that sucked and i had the money so i spent it on a really good set of electric fans
so how did you guys wire the windstar fans? one plug has three prongs and one plug has 2
The three wire motor technically has a high and low setting. I don’t remember which is which but I just set the power to go to the high wire.
